Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Brookstone Rover Camera Not Seen In ARC
I was configuring a project last night and at one point the camera in the brookstone rover quit being read in the ARC panel. Previously I had it chasing a ball,etc and it worked fine. I double checked the camera with the IPAD and it works fine. I have changed batteries in the rover and rebooted my PC, etc. The ARC panel is setup for brookstone rover, but all I get is a black screen.
I boot the s/w in this order...
  1. make sure I am connected via bluetooth to the ez B
  2. connect wireless to the brookstone rover
  3. boot the ez B software
  4. connect to the ez B
  5. open the brookstone rover Movement Panel and connect
  6. open the camera panel and change to brookstone rover
At this point, the camera feedback stays black.
I am at a loss as to why its not connecting. Help!
Sounds like you did everything right. I used the rover just the other day out in my front yard. I drove it around using the 3d augmented reality glasses:) its fun!
But I don't know what the problem you are experiencing is.
Dj, I am honored to speak directly with you. I learned to disconnect and reconnect the Movement Panel connection. It seemed to grab the video for the camera then and work.
I am having voice control issues as well. It does not seem to hear me. Checked w7 controls as you show in video. Can speak and see bars go up and down. However, can't get robot to respond to voice commands. Do I have to trane to my voice in w7? Are you using an external mic? I notice my version of easy builder has an enable and disable command with no reference scripts. Your video on line does not have these. Am I missing doing something?
I'm having the same problem but connecting/disconnecting did not help. It has never worked on my Rover. Any ideas would be greatly appreciated. Thanks, Nelson
Hello,
@mstephens_42 thank you:) i try to help on the forum as much as i can. Sometimes you may need to train the speech recognition. I haven't ever needed to, but there is a video floating around of a child using it and she had to train it. Follow the Tutorial section for speech recognition and i talk a little about configuring the mic volume.
@nyaple We tested the brookstone rover just now and it works great. I'm unsure what could be different within your configuration or wifi connection.
I'll try another computer and WiFi setup. The movement works fine, just no video. Very strange. I'll let you know what I find. Thanks.
Hmmmm... That is strange. I am actually sitting outside right now driving the brookstone rover around with my Augmented Reality glasses on! It's totally a new experience controlling it this way. I drove it down the street into someone's back yard - when they aren't home. It's like being on another planet. So surreal
I have the same problem with the camera. I can control the robot using the Movement Panel but no video has ever been seen.
Can someone suggest something to try?
Looks like it might be related to it running on a 64 bit system? anyone else have this running on a 64 bit system?
