Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
Hi guys, I apologize in advance if this is a repeat post. I tried posting it once, but not seeing it. Im having an issue with trying to setup a Ping Sensor and a Servo. I see the post about batteries and current, and just wondering if the ones im using will be ok, or not so much:( I have Energizers 2000 mah rechargeable batteries.
My problem is once i select the servo, it moves a few degrees, then disconnects the EZ B 4. In another post i found "You need a lipo, li-Ion, NiMh or NiCad battery pack" As part of a similar issue, from Richard R, and no mention of mah. Should i ditch these batteries for a pack, im guessing its a good choice anyway, but just curious if this could be the cause of the problem.
If the servo is drawing a lot of current then you will need a decent battery. If the battery voltage is low it will need recharging or a higher voltage. There are many things to consider when choosing a power source.
Personally I always advise LiPo batteries as I know they can provide enough current for most applications. Sealed Lead Acid are another choice however are old technology, heavy, big and not as efficient as LiPo or LiIon
Then LiPo it is! lol Thanks so much Rich! These are also about a year old and have been used quite a bit in photography flashes, so im sure there not even up to new standard.
Gys sorry for the distrubance please give comment a video on holiday robot contest
@dinesh You may not be aware of this but it's bad manners to insert comments that have nothing to do with the topic in a thread. It's called hijacking and people don't like it. Also people will see your other posts and your videos. No need to advertise in other peoples threads. There's nothing wrong with starting your own thread.
Sorey iam apologizing tired tired because it first
NP Dinesh, I understand:)
Thankyou:D wben i made any things i will show it to my parents but it is A seract job i need a comment to delovp this and so so so sorry :(:(
