Ez Line Chart icon Ez Line Chart — 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control Try it →
Auto Connect To Router
I set my robot to Client mode yesterday for the first time and everything worked fine.
Today I loaded ARC, turned on robot and the Ezb had changed to Ap mode.  Do I, every time i turn on my robot, have to set up client mode again?
EZ-B Settings by EZ-Robot
Configures and pushes WiFi SSID, password, system name and channel to EZ-Robot EZ-B v4 from ARC; saves settings with project for quick redeploy.
No.  Mine have stayed in client mode for years, often months between being powered on.  Are you sure you didn't hit the reset button?
Yes.  I would have to be pretty intentional to reset the controller.  I don’t think I could do it accidentally but thanks for the help. I am going to change it again and see if it holds. It is good to know that it usually holds.
I found out it was connecting to router.  I just thought it said it was not connecting and the IP address was wrong.
