Ar Drone 2.0 - Can't See The Camera Video Stream
Hello,
I'm trying to play with the ARC software (2012.06.20.00) and my new AR Drone 2.0 robot. I was able to use the Movement Panel to control my robot, however I do not see an image coming from the robot's camera.
I do see the AR Drone option in the camera control Video Device dropdown (after I connect to my robot using the movement panel), however I still see no image when I select it.
I believe I'm using the latest firmware for my Drone.
Also, do I need to buy the EZ-B or any other hardware if I want to implement color and face detection using my robot?
Thanks! Mike
South Korea
hey guys. the new ARC how to connect Ar drone 2.0. So I have a ARC update vision 2014.02.03.
Please only ask the question once, it will be answered. Posting the same thing in multiple topics only brings old topics to the top of the recent posts which doesn't help anything.
Drone 2.0 support is not yet added to ARC, if you read above you can see DJ has mentioned it is coming but there is no idea of a timeframe for the support. Since that was almost 18 months ago we can assume support may not come of may be quite some time still. I believe there was little to no support for the 2.0 from Parrot which didn't help.
In short, 2.0 support is not there. You may be able to use parts of the 2.0 by trying the control for the AR Drone 1.0.
