MPU9150 Accelerometer, Gyro, Temperature, Compass icon MPU9150 Accelerometer, Gyro, Temperature, Compass — MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand. Try it →
Aforge.Net Conflict With Sdk
How can I use the latest version of AForge.NET side by side with the EZ-Robot SDK?
Since the SDK has an aforge.dll and already uses AForge, I get a conflict when I try to include the actual AForge.NET dll's in the same project.
I've tried using extern alias to separate the two in my own code, but still get the conflict. I believe extern alias won't solve this conflict, because aforge.dll is referenced by other dll's outside my control, including the SDK's EZ_B.dll and AForge.NET's dll's, such as aforge.imaging.dll, aforge.video.dll, etc.
Is the SDK truly incompatible with AForge, or is there a way to write an application that uses both the SDK and AForge side by side?
Thanks.
The aForge DLL included with the EZ-SDK and ARC is slightly modified - but not very. You should be able to reference the included aForge library rather than the one you downloaded from their website:)
