PWM Servo Ramping icon PWM Servo Ramping — Smoothly ramps PWM servos on EZB D0-D23 via Vx-to-Dx mapping for natural, gradual motion without snapping. Try it →
ARC On Windows 10
I just purchased a new windows 10 laptop. When I try to download Ez -Builder it loads but comes up with terms of use box. I go through the pages and check the accept box. It then does nothing and when I close the box ARC goes away and won't run. I do not think it is a scaling problems. Any help would be appreciated.
It is a scaling problem. There is an OK button that isn't showing up. After hitting the check box, hit your tab key which will select the hidden OK button, then hit enter.
thetechguru: Thank you very much. Your advice fixed my problem. The program now runs and the scaling looks good so far. So once again, tank you very much.:)
