Afternoon All
I just want to confirm there are no 2 direction H-Bridge Controllers (back and forth)? I only see 4 direction options.
Thanks,
Daniel
Afternoon All
Thanks,
Daniel
@mulberry.
No you are correct. All the H-Bridge and movement panels are four directional. But one option is that you can have a mobile control and add just forward and reverse button controls with the relevant scripts if you wanted.
You don't have to use a Movement Panel to control an hbridge. You can just set the digital pins high or low to get the desired effect. Refer to my hbridge schematic on your other thread.
Thanks all. Scripts will be my next major project. Once I get at least one thing running
Daniel
No problem Daniel. Scripting looks daunting at first, but fun when you start to get the hang of it (as I'm still doing). Good luck.
