HMC5883 Compass icon HMC5883 Compass — Reads HMC5883 3-axis compass via I2C and updates EZ-Script variables on demand; polled control offers periodic heading data, for connected sensors. Try it →
The Remote Mouse tool can display the position of the mouse by returning the coordinate values. Are the button signals, left click or right click able to be used or monitored ? ( high or low (zero or one) )
I want to use the left and right click of the mouse in a script.
I know this may sound weird, but I want to use the input, local to the computer, not at the EZB. The screen will not be visible. The mouse will be used as a remote push button.
Possible ?
Otherwise a quick fix is a second IoTiny with two buttons.
I will give you a hint since you are new to ez robot... :) Look at the ControlCommand for all the options available for the remote mouse control...
Are you asking if you can detect mouse clicks rather than execute them? I don't think it can do that.
However, depending on what you are trying to do, you might be able to click on something else (like a script window start command) which you could then detect.
Give us some more background on your end goal vs how you think you want to implement it and we can give better advise.
Yes I would like to detect the mouse click. I want to use it as push buttons in a script. If not possible, I will have to add another iotiny with two buttons installed.
I don't want to use my phone either.
Hi Ron,
Yes you can automate the mouse pointer and the clicks. I do this with my Data and Spock projects because I have so much going on I always need to do a auto control set on the project load.
You can move the mouse and click things with in the ARC window and controls and even across the different ARC virtual desktops. It won't matter if you don't have display turned on or actively connected, however, you will need to have display in order to set the mouse position points and then if those ever change through like a driver settings or you change monitors, then all of your mouse settings will probably be off.
Thank Richard, but not the functions I want.
Hi Justin, It looks like it is not going to work for me. I will have to pull an IoTiny out of something and just add the buttons. The "remote" will be kept in my pocket.
Thanks to all..
Just for clarity, I wanted to be able to control to functions on Antonn. The Latte panda is installed in him.
I agree Ron, for your application it won't work. There is the joy stick control in ARC for the Logitech Gamepad F710 wireless joystick, Amazon has them for about $40.
