Ultrasonic Collision Script icon Ultrasonic Collision Script — Ultrasonic sensor triggers custom script on object detection; configurable interval & min distance, with optional forward-only trigger for navigation. Try it →
South Africa
Jd Examples Download
Hi
New to this and I need help with 2 things please
  1. the example downloads are not downloading anyway I can find it manually and download it.
  2. Then when I get to the second page of the assembly process the files are not there.
Please help....attached is the 2 pics of my error msg
Thanks
stress
The example files and the assembly instructions are installed with ARC. Uninstall ARC, reboot, reinstall the latest ARC. That should solve any issues you are having.
South Africa
Thanks I will try that....
South Africa
Na still the same files missing attached screen shot
stress Thanks for the help
So press "Sync" to download the library (the missing files)...
To help us, can you tell us what confused you with the popup message for downloading the files? Could it have been worded different?
Thanks!
Can you show us "the second page" where you say the files are missing?... I just did this and everything is as it should be on page 2....
South Africa
The page that says it's downloading the file as been doing that all day is that possible
South Africa
It has been stuck on this page all day there is nothing showing if it is downloading and how much if at all/. Is there no way I can download the files and open them in ARC manually
