On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
It’s part of ARC native, so no. But do you want it bigger or smaller?
To be able to increase the window size would be good. It usually shows only 5 or 6 command words with the rest off the screen.
Okay - will do! Stay tuned:)
Can you show a screenshot of this happening? I'm unable to reproduce this behavior of words off-screen and wondering if there's something I'm missing. Thanks!
Sorry for the delay. Here is a screen dump. There 15 numbers in this prompt. I will look at the update you have done. Thanks,
Holy cow, 15? I didn't account for that. You will run out of screen height eventually because your screen is only so big. But I'll make it scale for the text size in a future release for ya
Usually it would only be 8 to 10 key words. The numbers is this example, referred to 15 questions with the robot giving answers.
