3-In-1 IMU icon 3-In-1 IMU — EZ-Robot 3-in-1 IMU driver: accelerometer, gyroscope and compass support for motion sensing, orientation tracking and heading/navigation. Try it →
Spain
large file bug
Hello, I have had problems with ez-saving project builder, I have installed the latest versions of ARC and filmware. After adding the function "recorder" menu scripting and recording a sequence of movements of servos, saving the project went well, but I went to open it again this message
I have also noticed on other occasions it was not possible to record on a project a sequence of movements of the "recorder" of ARC , I mean that when I opened the project and the recorder did not appear in it. I tried opening the project in my pc and my pc laptop with the same result, both windows 7, I attach the project file that has this error: cabeza.EZB Appreciate any help, thanks stress
Spain
Okay, I updated my other robot filmware and have proven again, confirmed, receive the same error message when I save the project after recording a sequence of movements with the option "recorder". So you can not save a project with the sequence of movements recorded? You have to record the sequence in "recorder" every time you open the project or is some kind of software error?
Hmm, i cannot reproduce the issue. I'll look into it more for ya
Hi DJ, Have you had a chance to look at the Recorder file saving issue? I have experienced same problem than R2D2, and my case after triying to save it becomes impossible to reopen the project file. stress
Spain
I upgraded to new software ARC and filmware today. and I re-tested on PC desktop and laptop pc and the error is the same. Same error message and can not be opened after the project. I have windows 7 on my two computers and have done all kinds of tests on the way to record or save the file, it is quite frustrating after so long, any solution DJ? Thank you.stress
Large recordings will cause your computer to run out of memory. There's an item on the list to look at a different way of storing the information.
Spain
DJ Sorry do not understand, no memory? the laptop is a Core i3, and 6GB of ram. Any suggestions on settings of windows 7? No wonder that the two computers do not operate the recorder? confused
Spain
Besides the recordings are not great, I've proven with my recordings of 3seconds of time and one servo.
S.O.S Having problems with this one confused Not sure what you mean DJ ?
