Is there a way to suppress the printing of Start, Done(timestamp) when a script is executed? I am building a state-machine interface with EZ-scipt, and I want to make it as fast as possible, eliminating any unnecessary prints.
jsale
How To Suppress Print Outputs On Scripts
EZ-B V4
by EZ-Robot
Servos
24
UART
3
ADC
8
Digital
24
I’ll add an option for you. Have you considered using the JavaScript compiler instead? It’s 10-20 times faster than ezscript
Thanks DJ. I coded a simple state-machine to do some movements for 3 of my 8 servos/motors per arm, and it seemed to work fairly well. Still have a lot to add to it though, so speed might eventually be an issue.
I was thinking about C# code, but I think I'll give the JavaScript a shot. Might be just want I need. I've done some Java, and lots of C programming over the past 35 years, so I shouldn't have much trouble getting up to speed on JavaScript. Thanks for the suggestion.
