hi where can i find all the stl files from ez robots?i see 3d printing is gone.
Dual Hbridge W/PWM
— Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning.
Ah ok.i used same as original jd.just changed the lever servo whit an rotation servo.thank you
No problem - you will find the robot designer in the My Robot menu item of Project tab. See above post
sorry i forgot.works
thanks
