Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
Which Battery Should I Use?
i am trying to create a mini wooden tank run by windshield wiper motors
i am going to control the motors with a bunch of servo switches and wanted to know if it's ok to power both the ez-b (connected to about 5-6 servos) and both motors with the same battery
if so
which one of these should i buy (is it ok to go over 5 -- i don't want the fuse to blow up)
www.amazon.com/6-0ah-Battery-Razor-Electric-Scooter/dp/B005V0DLXM/ref=sr_1_42?s=electronics&ie=UTF8&qid=1344479402&sr=1-42&keywords=12v+rechargeable+battery
www.amazon.com/Generic-SLA-7-12-VOLT-BATTERY-Battery/dp/B000R9PYEQ/ref=sr_1_16?s=electronics&ie=UTF8&qid=1344479299&sr=1-16&keywords=12v+sealed+lead+acid+battery
www.amazon.com/Elk-ELK-1280-Sealed-Lead-Battery/dp/B000HB03MM/ref=sr_1_2?s=electronics&ie=UTF8&qid=1344370551&sr=1-2&keywords=12v+sealed+lead+acid+battery
www.amazon.com/gp/product/B0010Z4MDK/ref=ox_sc_act_title_1?ie=UTF8&smid=A1WQSUFM2GVFFG
The 5A is too small. Windshield motors consume lots of power, especially when they are used with a heavy load. Try at least 7 or 8 A, if possible 2 pieces in parallel. Take my word for it... Good luck !
if i power both the motors and the ez-b (with multiple servos) to the same battery, will it effect performance for both
wouldn't it blow out the fuse for the ez-b if i go over 5amps
Go with 2 X 11.1 volt (2.2 amp) Lipo's. 1 for the EZ-B and your servos and 1 for a H-Bridge to run 2 motors. (you might also need a speed regulator to reduce the voltage to your Motors). You will also need a charger for the Lipos to balance them. I've had my completed robot Bob wizzing around the house on voice command for some time now and after trying everything, bang for buck, lightness and power they are an excellent choice.
2 x Lipos, 1 X speed controller, 1 x battery charger - (these items are not expensive, shop around or try my supplier.
  • Richies RC and Robotics at
Richies Robotics
The 11.1 volt (2.2 amp) will not hurt your EZ-B Board.. I don't think it would hurt to invest in a fan blowing over the board - espeically if your drawing power through to a bunch of servos coming off the board.
Good Luck
@wallekid1
I'm using 2 power supplies for the EZ-B, one small battery pack for the EZ-B board and a 12V SLA for powering the motors. If you're connecting lots of servo's it's necessary to re-wire the cables and use a seperate power source for the servo's. You just need the PWM signal from the EZ-B to control the servo's. Show us some pic's, it sounds interesting.
@wallekid1
A circuit will only draw as much current as is required for it to operate.
Individual loads such as L.E.D's draw a specific amount of current and will require you to limit the current through them by using components such as resistors. Google "L.E.D. calculators" to see what I mean.
With motors there are few things you should pay attention to. The first is operating current. This is the average amount of current the motor is expected to draw under a typical load or torque. Multiply this number by the rated voltage and you will get the average power draw required to run the motor. Motors can draw a whole lot of current for a split second when first energized. The other current rating which you need to pay attention to is the stall current. This is when you power up the motor, but you put enough torque on it to force it to stop rotating. This is the maximum amount of current the motor will ever draw, and hence the maximum amount of power too. So you must design all control circuitry capable of handling this stall current. Also, if you plan to constantly run your motor, or run it higher than the rated voltage, it is wise to heat sink your motor to keep the coils from melting.
See some of these links to help you understand.
Select the Right Battery for your Robot DC
societyofrobots.com
battery_calculator
loganbot.com
letsmakerobots.com
A good electronics tutorial link is:
allaboutcircuits.com
thanks rgordon (i'll look into that)
are any of you guys on instructables.com (in case i have questions in the future)
@PhG --- i am rptech (the guy who posted that thread for the servo switch)
you can find me here --
https://www.instructables.com/member/rptech?show=INSTRUCTABLES
the thread about wooden tank tracks is what i plan to modify, they didn't work at first so i'm going to turn it into mini wooden tank
just one last question (to everyone), if i do use two power sources, one for the two wiper motors and one for the ez-b with 5-6 servos and 2 sensors (no led)
what specifications do i look for in each battery (how many volts and how many amps) --- (no regulators or resistors and what not; just direct connection)
p.s. sorry for stretching this question (first time shopping uncommon batteries)
