Hi everyone I wanted to know if the tomy robie sr can have the same features as the tomy omnibot 5402
Lars
Holland
— Edited
Serial Terminal
— PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex
Pretty much, the main differences are that the robie has a different head.
What features are you hoping to add to it?
The Robie Sr is basically a Hearoid as far as the bits we use are concerned, feel free to have a look at Melvin for ideas and to judge if you want to use the Robie or go for a 5402.
I want to know if he does random things in the house like a pet
If you add the EZ-B, sensors and servos and program it to then yes.
Is it very difficult to to make your robot
The EZ-B makes it all very easy. The hardest part is the physical modification to the old toy robot and then even that's not too difficult. It all depends on what you do mind you, some things are trickier than others but the EZ-B side and ARC side of it is very easy, and if you get stuck this community is always there to help you out.
Ok thanks for your hel
@Lars this is the number 1 place I've seen for customizing Omnibot toys into modern robot pets.
