Virtual Robot icon Virtual Robot — Display robot image with real-time servo position readouts and basic servo management including servo deletion Try it →
Unknown Country
What Is The Ezplugin File?
What is the ezplugin file in virtual reality robot?
USB
Digital 21
Immersive Meta Quest VR control for Synthiam ARC robots: stereoscopic camera view, map servos to hands/controllers, plus built-in remote desktop.
The ezplugin file is a type of file used by Synthiam ARC to install robot skills. When you download a robot skill from the Synthiam website, it comes in the form of an ezplugin file. This file contains all the necessary code and resources for the robot skill to function within the ARC software.
To install a robot skill using an ezplugin file, you simply need to open the file with the ARC software. ARC will automatically install the robot skill and make it available for use in your projects.
Please note that you should only download and install ezplugin files from trusted sources, such as the Synthiam website, to ensure the safety and functionality of your robot projects.
