Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
#17
If the ez-b didn't turn on, that adapter may have had the incorrect polarity. The polarity is positive (+) in the middle of the plug, and negative (-) on the outer side of the plug. The plug is actually called a Barrel Plug or Barrel Jack.
Most of the transformers that you will find around the house are not digital switching. They use a transformer, which is two wounds of wire at a ratio which conducts electromagnetically across the two and produces a lower voltage in respect to the wire ratio. What that means is, those transformers literally only contain a spool of wire that lowers the input voltage by a pre-defined ratio. Then a simple Diode is used to flatten one line of the AC current to produce simulated DC current.
In short, a transformer power supply is not a great selection to power a robot. A digital switching power supply is the best option - specifically one with providing between 6 and 8 volts DC current at more than 6-8 amps for your application. If you add more servos, the number of amps will need to be increased.
If you want to get crazy, use a PC power supply:) That's what we use!
#18
Like a power cord that I have for my laptop? Mines a ac adapter that has an output of 19 volts and 3.42 A
#21
You should buy this though....7.4v 5200mAh Lipo You can use the ez robot charger to charge it. It is a big battery that will last much longer than the 1300mA ez robot battery...
#22
I use the basic 6 aa batteries. They last about 5 hours, so I think for now I'll get more to swap out.:)
#23
Wow, 5 hours on the 6 aa batteries is great! I would not have expected that. I'm looking forward to seeing a video of your robot when he's ready!
