Microphone icon Microphone — Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback. Try it →
That was on the little wall-e i had built. It was from the Interactive Wall-E. I don't recall what wires I used. I can check the robot when I am back in Calgary. I'm currently 2,400 KM away for the next 3 weeks.
Netherlands
That's right I have the Wall-e I. I've watched your movie a lot of times and just can't see enough to try it.
Okej that's far far away:)
On a holiday ?:)
If so enjoy !!
bump, can this be added to a big wall-e (u command wall-e?)
Netherlands
Don't know, have to wait until Tuesday. Than i get my "U Command Wall-E"
The interactive wall-e it was easy to do, if you watch the demo movie of the making off wally by Djsures.
But if the U command layout is the same as the interactive it's just seeking for the right connection and solder away:) Trying is the best way:)
