for Bluetooth is it possible to not be hooked up to a loptop?
ex: is it posible to control a robot with a bluetooth joystick while away from the orinignial blutooth source?
Stream All The Video Sources
— Stream video from any URI/protocol (RTMP, RTSP, HTTP, UDP, etc.) to a selected ARC camera device for real-time network feed playback.
you could use the HTTP sever however you would still need a connection through the laptop. Though I am sure you can create a different microcontroller that can connect to the bluetooth on the ez-b u would then have to know the protocals sent to the bluetooth, doubt you want to go that far into the rabbit hole.
thank you very much, i relay appreciate it.
