Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
you could use the HTTP sever however you would still need a connection through the laptop. Though I am sure you can create a different microcontroller that can connect to the bluetooth on the ez-b u would then have to know the protocals sent to the bluetooth, doubt you want to go that far into the rabbit hole.
thank you very much, i relay appreciate it.
