Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
#33
Any chance there will be release tonight?
#34
Yup, in about 45 seconds:)
#35
LOL..glad i did not goto sleep well done!
#36
Okay, the new version is up. If you already have updated to 15.3, you will have to update again and it will fix your issue.
If you already have the buggy version, you'll have to try the quick power recycle in order to receive an immediate pulsing LED before updating.
If anyone is having trouble recovering from the buggy firmware, let me know and i'll try to help you.
I'm tired:) Sleep time!
#37
Fantastic work. Get some rest.
Netherlands
#38
I do have problems updating from the buggy software.
I have downloaded and installed the new version. I have i reset my bluetooth device, when i try to update it i get a message saying..
Attempting connection to COM3 Connection Failed: System.IO.IOException: The semaphore timeout period has expired.
at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str) at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace) at System.IO.Ports.SerialPort.Open() at EZ_B.EZB.Connect(String portName) Disconnected.
*EDIT
Never Mind, I have got it to update. After installed the new version, it had 3 different ports set up. Before I had the com3 and com4 port. This time I had Com3, Com4 and Com5. Turns out that the Com4 port wasnt really assigned to be any port at all. so I took that out and then it updated.
Netherlands
#39
Thanks for your work DJ! My EZ-B is working perfectly and the new update is GREAT!:D
Kristian.
#40
The power cycle does not result in an immediate pulsing led. It will always just stay on for a bit and start pulsing. I am not sure what I am doing wrong. What else can I try? Thank you in advance.
