EZB Stress Test icon EZB Stress Test — Stress-tests EZ-B controllers (UART, ADC, voltage, temp, audio, digital I/O) to detect disconnects, corruption and stability issues. Try it →
Unable To Connect To Andoid Phone
At one point to the robot would connect to my smartphone with out any problems. stress By my mistake in deleting the wrong wi fi profile from the phone. I am unable to connect it back to the phone. I keep getting the "avoided poor Internet connection" after about seven minutes of obtaining IP address.... I see where I can input values manually but I need to know setting in order to config the phone to reconnect or any ideas from the community or the ez-robot experts in getting the connection back on the phone. (connection to desktop computer works with no problems) confused
delete the profile that your android phone created for the ez-b. You will never need to "configure settings" for the wifi connecting to the ez-b. The dhcp takes care of that .
Because every Android device is different, i'm unable to tell you what menu options to use to delete the device. Unfortunately, Android doesn't have a support specialist either - maybe someone on here has a similar device with a similar menu configuration that can help you.
