Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
Type Or Namespace 'ezb_connect' Does Not Exist In The Namespace 'ezb'
Type Or Namespace 'Ezb_Connect' Does Not Exist In The Namespace 'Ezb'
I'm trying to install the C# SDK and I get the error messge "the type or namespace 'EZB_Connect does not exist in the namespace 'EZB'... showing up in Form1.Designer.cs. Can anyone offer a solution? I'm using VS Community 2013. See attached screen shot.
you need to copy all of the EZ-B SDK DLLs to your project build directory. See the SDK release notes.
Make sure you have included the ezb.dll file as a reference to your project along with having the correct .net framework.
I have done that and the error message still comes up. The framework is 4.5. Other suggestions?
Is EZ_B in your references?
Is Copy Local set to True?
Is it in your project directory?
are you using an example DJ provides or building your own project?
DJ gives an example of what needs to be layed out in your code if its a new project Here.
Also don't forget to add the .dll to your tool area.
EZ_B is in the references, Copy Local is set to True and the files were copied to the bin/debug folder of the project as specified in the Installation Notes.
If you install team viewer 10, I would be more than happy to connect and see if I can figure it out.
orwnic82, I am using a project from the Tutorials page. This is what shows up:
private System.Windows.Forms.NumericUpDown numericUpDown2;
private System.Windows.Forms.NumericUpDown numericUpDown1;
private EZ_B.EZB _ezb;
private EZ_B.EZB_Connect ezB_Connect1;
It is EZB_Connect in the last line that has a squiggly blue line under it and the message "The type or namespace 'EZB_Connect does not exist in the namespace 'EZB' (are you missing an assembly reference?)
