HTTP Server (Custom) icon HTTP Server (Custom) — HTTP server for ARC serving HTML/CSS/PNG/JPG from ARC/HTTP Server Root; supports AJAX tags (ez-move, ez-script, ez-camera) to control the robot. Try it →
Tutorial Improvement
i just read the tutorial off the ping sensor.what i notest is the pic off the, ezb how its wired up is hard to see.also it dont mention where the , in or out off the 5 volt regulator goes. i believe its in goes to ezb and out comes from the sensor ?is this correct ?
ping tutorial
The tutorial that you linked to has specific and detailed written instructions that you must have missed. Here is a direct copy from the tutorial...
Quote:
Ground = Black wire from regulator PCB to D21 black pin Power = Red wire from regulator PCB to D21 red pin Trigger = white wire to D21 White pin Echo = green wire to D22 White pin
and the 5 volt regulater is that correct?
thanks dj
