Servo Summary icon Servo Summary — All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit. Try it →
Trouble Updating To Firmware V16.0
I've been trying to update the firmware from version 15.8 to 16.0. After the Boot Loader progress bar finishes nothing happens. The screen messages stop. Two previous firmware updates went without any problems.
Attempting connection to COM9 EZ-B reports EZ-B Firmware V15.8 Connected Starting Keep-Alive Keep-Alive Disabled Starting Boot Loader...
sending ping sending ping sending bootloader I am EZ-B BootLoader. Gimmie Firmware!
Updating... (22,656 Bytes)
Have you watched the tutorial video? If so, is anything different? For example, does the LED start flashing while the bar is moving, etc?
DJ,
The LED only flashes while the screen message is being displayed. After the message is displayed the LED stays on and the progress bar moves.
Jim
Does the led flicker while the progresss bar moves?
DJ,
No. The LED only flashes during Starting Boot Loader... and stops flashing and stays on after sending ping.
Jim
Do you have the native Microsoft Bluetooth stack?
DJ,
I'm not using Bluetooth. I replaced the Bluetooth module with an XBee setup months ago. I did a loopback test on the Xbee modules and they tested ok.
Jim
Is the baud rate set to 9600 on the port?
DJ,
Yes, 9600. The Rx and Tx LEDs on the XBee module connected to the EZB seem to indicate some type of timeout or loss of communication shortly after the progress bar finishes.
Jim
