Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
South Korea
Too Thick Barrel Jack For Thin Power Adater
Dear EZ-robot, A few days ago, I received a EZ-Robot Developer Kit in the Order ID: 12-5280. Unfortunately, it has a problem. I cannot put the power adapter into the barrel jack of the controller holder. The reason is that the barrel jack is too thick for the thin power adapter. Can you help me, please? Sincerely, Youngmo Han [email protected]
Use Contact Us to report the defect and they will get it sorted out under warranty. There was a manufacturing error on a recent batch.
You can also try and get a 2.5mm barrel jack from a local electronics store. That way you can be up and running much sooner... Ebay is another option, but that will take longer to get to you.....
