Bing Speech Recognition icon Bing Speech Recognition — Accurate Bing cloud speech-to-text for ARC: wake-word, programmable control, $BingSpeech output, Windows language support, headset compatible Try it →
Suggest A H-Bridge?
Hey Guys,
First time poster, I was wondering if I could get some advice from the veterans.
After seeing DJ's wall-e robot, I've been working on making my own for a while. Originally I was looking to do it using a netduino as I'm a .NET developer but kept hitting some bricks walls I couldn't get passed. So now I'm looking to move it over to using the EZ-Robot platform.
You can see a few pictures of what I have so far here:
dl.dropbox.com/u/138129/Host/wall-e/bottom.jpg dl.dropbox.com/u/138129/Host/wall-e/servos.JPG dl.dropbox.com/u/138129/Host/wall-e/arm.JPG dl.dropbox.com/u/138129/Host/wall-e/head.JPG dl.dropbox.com/u/138129/Host/wall-e/pivot.JPG dl.dropbox.com/u/138129/Host/wall-e/full.JPG
As you can see, for the wheel motors, I'm using a Tamiya gearbox running some brushed DC motors. For the motors I have 2 options available, which are:
www.pololu.com/catalog/product/1117 www.pololu.com/catalog/product/77
So my question is, could someone suggest which would be the best motors to use? and also recommend the cheapest / easiest H-Bridge to use that works with the EZ-Robot platform? If you have a link to how to wire it up with the EZ-Robot board aswell, that would be awesome.
Cheers guys
Matt
Spain
Mattbrailsford Welcome! Visit this link to the motor controller 2.5 A of ez-robot: 2,5A motor controller And relative to the engine I think this is more appropriate because it works to 6v: Brushed DC Motor: 130-Size, 6V regards
Hey R2D2,
Thanks for the recommendation, that's exactly what I am after.
One question, on the video is shows DJ bridging the 2 enable pins to control the motor via PWM. Would I be right in assuming that if I want to control 2 motors at different rates, I wouldn't bridge them, instead run two cables and use two PWM controls? (I assume you can choose the port in the config to the PWM).
Many thanks for your help.
Matt
