Avatar JD icon Avatar JD — 3D Avatar JD simulator with bidirectional servo sync, action sequencing, $SIM_ scripting, EZ-B emulator support and pose/movement visualization Try it →
Resolved Resolved by Rich!
Stupid Question About Voltages
What is the Maximum voltage suggested to run the EZ-B? and what is the minimum. I have ran it fine on 7.5 volts. But, I would like to run it on 12VDC which you know can go upto 13.6 unregulated. What are your views on this?
thanks,
MM
Technical manual here
EZ-B Version 3.1 Input Voltage (min): 5 Volts DC Input Voltage (max): 17 Volts DC Input Voltage (recommended): 7.2 Volts DC @ 3 Amps
Your proposed supply will be fine.
