Myo Gesture Armband icon Myo Gesture Armband — Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands. Try it →
Re: 2017 Spin Master's Hero Droid BB-8
Greetings,
I purchased my little droid back in 2017. As everyone knows sooner or later the rechargeable batteries will no longer accept a charge. In addition, Spin Master never anticipated the consumer having an interest in replacing the batteries. I am sorry, I spent $229.00 on this toy. I am not about to throw this toy in the trash, or place it on the shelf to collect dust.
Well, I reached the point where the batteries (Body/ Head) needed replacement. I have taken my BB-8 apart and replaced the Six AA battery pack (light green in color) with a Six AA Battery pack that I found on amazon. NI-MH 1800mAh 7.2V dc. The unit moves slowly (Sphere Only), and the play time has been shorten, fifteen minutes to be exact. Now, we all know that the play time with the OEM batteries was limited. Half an hour of play time at best on a full charge.
I found another brand battery (HyperPS (UPC: 616929581751) on eBay, This battery pack is designed for RC Toys. I installed that battery, and it takes (2 1/2 hours) for a full charge. However, the unit (sphere) moves slightly faster. It still runs half the time if you want BB-8 to follow you, or if you use the remote control. If I do not use the remote and allow BB-8 to run on his own, he lasts longer between charges. About half an hour to forty five minutes.
As mentioned above, I replaced the battery in the head as well (3.7V 400mAh) 702035. But didn't make any performance improvements. When I am referring to slow, I mean the sphere. His head, and reactions to my voice are normal.
I do recall how fast BB-8 at the time purchased. It was difficult to maneuver him in small areas. I was aware of the head connecting the body issue. However, all you had to do is twist the head ever so slightly, you would feel the magnets making full contact. Needless to say, my BB-8 never came off in that fashion.
I did contact the company, Shida Battery Technology Company, Ltd. They did not respond. Then, I contacted another battery company, and they only sell these batteries in bulk. I was also informed by a Chinese Customer Service Representative  that these batteries are dangerous. Well, if that is the case, why are they being placed in Children's toys in the US?????
A few years back, I purchased two Hasbro Star Wars Astromech Interactive R2D2 Droids. I am so happy that they require house hold batteries as opposed to rechargeable batteries.
So I am here to discuss the reasoning for the slower moving sphere. Are there missing specs on the OEM battery pack that were not printed?
Any suggestions would be greatly appreciated.
Thanks in advance.
Jonathan
Could it be another issue and not the batteries? Maybe age has hardened up lubrication somewhere or motors are wearing out?  Maybe overheated solder joints or bad connections linitting amperage draw?
I believe not, and I will tell you why.
I purchased another BB-8 off of eBay. It did not come with a head. I placed my BB-8 head on the sphere  from eBay, and it performed as expected. Fast!
I dismantled the sphere from eBay, took the battery out, and placed it in my sphere. BB-8 ran like new.
In reference to liberation, my hands were covered in white grease. I checked all wired connections by unplugging the connectors, removing the wires for inspection. I even removed the board and examined the soldering points. Everything appeared to be in fine shape.
This toy doesn’t have that many miles on it. I never took it outside as documented in the manual. In short, it has been exposed to light usage.
This is puzzling, and I am determined to find out the reason why.
Question for you. If I were to purchase a battery with the specs of 2000 mAh or higher. Would that make a difference? Or am I just wasting my money?
jonathan
Well, I'm not a battery guy. I'm know more about AD & DC power. However I do know that amps are where the power comes from. Voltage is just the pressure that pushes the amps. If you are delivering the rated voltage then you probably need a bigger amp pool to draw from.
I did a quick google search on your module of BB8 and found several videos on replacing the batteries on this little guy. there is one youTube vid where the guy gives an Amazon link to the body battery in both his description and the comments below. Both batteries links are not available anymore but one shows that he used a 7.2V 2400mAh Ni-MH AA Battery Pack SM-2P 2Pin Plug. After he replaced his old battery with this one the BB8 rolls nice and quick. Here are a couple of the links I got this info from for reference to find the proper battery. Do your own Google search for more results:
Link to the battery - (Not available) 2400mAh battery on Amazon - Not Available
Here's the Youtube video showing the replacment and results:
Unknown Country
#13   — Edited
The better battery replacement is an 18650 lithium ion 4 cell pack in a 2s2p configuration.  This will get 6ah vs 2.6ah for the stock battery and will not have the memory issues as the nimh batteries.  The charging circuit will have to be replaced, but it is a simple operation.  Search for "7.4V 8.4V 8A 18650 Charger PCB BMS Protection Board for Li-ion Lithium Battery Cell" and "3000mAh 18650 Battery Rechargeable Samsung30Q" in your favorite marketplace.  The cost should be under $40.00 usd for the replacement.  This is the battery for the body, not the head.  I haven't replaced the lipo head battery yet.  I believe it is also a 1s 702035 400mah lipo battery.  I will have to see if I can disassemble the head and measure the available space for lithium ion cells.  14500 - is smaller but similar in size to a primary AA battery. Capacities are typically under 1,000 mAh.  This should double the capacity in the head with just one cell and quadruple the capacity with 2 cells in parallel.
Re: SpinMaster’s BB-8 Hero Droid con’t
Finally, I discovered a resolution to my issue. It was a due to main drive motor showing its age.
Mike, who has posted many videos on You Tube about this toy showed how you can turn BB-8 into a puppet. By doing this, I was able to see just how much of a battery charge was being held by the six AA battery pack located in the sphere. It also makes troubleshooting a lot easier.
Previously, I had commented about the sphere being very slow. Well, I discovered what the problem was. I took the mechanics out of the sphere and place it into puppet mode. As the motor was spinning, I began to see smoke. This was an indication that the motor was beginning to seize. Could this be one reason why the toy will only last for a total of 15 to 20 minutes of play time under a single charge. To give the motor a chance to cool down?  Very dangerous!
Luckily, a year ago I had purchased an additional sphere from eBay. And I’ve been using those parts as replacement parts. I replaced the main drive motor and now my BB-8 is acting like New. It’s a heck of a lot faster, the batteries are holding a charge longer because of less friction, and he talks up a storm. Once linked, he stays linked.
What scares me the most, is if you read the black and white manual it indicates that if you should have a fire, you should apply sand or fire extinguisher to the batteries, not mentioning any other part that may overheat. And this toy was meant for a child? What was SpinMaster thinking?
SpinMaster recommended that you should not play with this toy outdoors. But considering of what this toy is capable of, I don’t think it’s safe for indoor play.
Thoughts?
#15   — Edited
Yikes! That is scary! It must be an issue if they need to include instructions on fire control in the owners manual!:(
I just bought a hand held vacuum that said in the owners manual not to use it more then 15 minutes without stopping to let it cool down. Oh my! What the heck! Now I have visions in my head of it bursting into flames right in my hand while I clean my car.
However I'm glad you stuck to it and found solutions to the main problems. It's always good to overcome. Thanks for sharing and the update.
Now get out there and buy a fire extinguisher!;)
