Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
Speech Recognition
I having a problem with microphone level setting under the setup microphone property from the speech configuration .Every time i open my project i noticed that the microphone level shows level 0 under microphone properties.What do i need to do so that microphone listen level stays were i set set the slider..Typically i have it at 80. Windows 7 pc.
That's a global volume setting. In your connection control "On Connection" script set the volume using the EZ-Script command SetVolume()
Thank you for your help. It is truly appreciated..Absolutely love EZB4.
That's excellent to hear:D
