Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
To adjust the volume of the speaker on the EZ-B IoTiny, you can use the "SetVolume" command in ARC. This command allows you to set the volume of the speaker to a value between 0 and 100. You can also use the "Mute" command to turn off the speaker completely. For more information on these commands, you can refer to the EZ-B IoTiny datasheet on the Synthiam website.
@smiller29 If you'd like you can also overdrive the EZ-Bv4 and IoTiny speaker with SetVolume(200);
Playing music with a lot of bass will be more clipped and distorted but it works with text-to-speech pretty good:)
