Output Audio From EZ-B icon Output Audio From EZ-B — Example ARC skill demonstrating converting, compressing and streaming MP3/WAV to an EZ-B speaker, with play/stop commands and TTS examples. Try it →
France
Resolved Resolved by Steve G!
Servo Motor D13 Of Ez Robot Out Of Order
bonjour j'ai un problème avec le servomoteur gauche du genou. Celui chauffe anormalement et il tremble rendant impossible toute stabilité. que dois je faire ? celui qui branché en D13 pour être certain que le problème vient du servomoteur je l'ai validé et branché en D15 et le problème est le même
I have a problem with the left knee actuator. This heats abnormally and making it impossible to shake stability. what should I do? the one that plugged in D13 to be sure the problem is the booster I validated and connected in D15 and the problem is the same i observe the same thing
thank you
No problem. What did you do in the end to resolve the issue?
