Sketch Pad icon Sketch Pad — Script-driven Sketch Pad for ARC: draw shapes, text, lines and faces via controlCommand() to visualize object locations, paths and robot data. Try it →
Spain
Script Manager And Script Pauseon
You can pause a script and then unpause? I'm trying to run my personal radar control and I have a script that moves the servo ping sensor, but I would like to pause the movement when turning to avoid obstacle and then unpause to move forward. I have proven this if successful: CC ("Script Manager" ScriptPauseOn, "radar") Not if it is misspelled or does not exist the command "PauseOn" for Script Manager I have also proven with the command PauseMS but seems not to work. Thanks in advance for your answers:)
Spain
#41
Cool, ultra portable robot. Batteries and me neither friends since we discovered lipo batteries a few years ago, but for a vehicle of evidence; aceptaria even duct tape:)
#42
The whole thing is put together and secured by tape:)
I could fit a 5000mAh LiPo in the white box (one come in the white box) but I don't want to use a LiPo on this as I always worry about them going under voltage.
The 6xAA battery holder fits on the back nicely or under the EZB, so I'll be using that. Also, the camera has now been added too. I'll do a project showcase for it when it's all done and looking pretty and stuff.
Hi Rich, I use Lipo on my robot, Hobby king sell an under voltage alarm for use with electrical planes. This has a warning LED when its getting low and then a Pizo alarm when it hits rock bottom for the cell. $3.49 US https://www.hobbyking.com/hobbyking/store/__7226__hobby_king_battery_monitor_5s.html
You could take the signal to the pizo and piggy back an alarm to the EZB or alternatively hard wire a master power relay so this alarm will cut power to the entire bot. The alarm connects to the cell monitoring port not the Battery cables them selves so it monitors one of the individual cells for the min voltage.
regards ghost
#44
Just made a new post with a new idea in it:)
Hopefully it'll work.
P.S. I have one of those alarms but I've already had to split my balance port to 2 (1 for charger and 1 for monitor), I'm reluctant to split it to three.
