Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Script Help Please
Good Morning,
I have created two arrays. I am trying to speak the contents of the arrays with the SAY command. For Example:
code SAY("This is" + $ARRAYONE[0] + "good work" + $ARRAYTWO[0]) /code
When I run the script I get the error message: Variable is in array: $ARRAYTWO[0] Which makes me think that I am trying to add. Do I have the syntax correct?
Ok, converting them to a "regular" string worked. Why?
Not sure dude... Maybe DJ can answer that... Although my way worked, maybe we are missing something simple and there is actually a better way to do this...
How do you trigger this thread so that he can see it and need to chime in on it?
He will see it, he is like Santa, he sees everything:)
