Servo Summary icon Servo Summary — All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit. Try it →
I'm working on an idea for a robot based on the Roli, but I need to change some of the dimensions to make it lower and wider. I went to the resources page, but there doesn't seem to be a download link for the Roli. Are these files available?
Roli files are not available because it can't be printed due to requiring gears and axels. Also, you can't edit an stl. I would recommend using a cad software program to design your robot.
Gibraltar
I know it's not printable but good for reference. check dimensions though Rover5.stl
Thanks Bborastero, that will give me the help I need; the measurements will save me a lot of time.
