Going thru the step by step I noticed all the servos are Heavy Duty
Are these the same ones sold on this site?
What power supply did you use?
What size 3d printer do I need to purchase to print the hexapod?
Cube or CubeX?
Advanced Speech Recognition
— Azure Cognitive Speech recognition for ARC with custom API credentials, scripting, language control, and text output for detected phrases
Cube or CubeX?
Every EZ-Bit has an (I) button. When you press the button, it shows you the STL files and information. The information for the suggested printer is within each part.
Heavy Duty servo can be found in our store. It is called "Heavy Duty Servo".
So the Makebot replicator 2.
Cool thanks
