is there a way to replace bluetooth with usb cable
bborastero
Gibraltar
— Edited
4 Participants
If you use a TTL usb adapter, yup
Connect the RX and TX lines off the TTL usb adapter to the EZ-B plug and voila
Excuse my ignorance Will EZ B still connect to ARC for programing i want my bot to be autominous so i don't mind not having BT control over it
Yes, My omnibot has a USB->TTL adapter i got from SparkFun and it works just like the Bluetooth.
hay niek could you give me link please
Got rx/tx connected to usb, soild LED, could you tell me how to find com ports in windows xp or what to do to connect to ARC
Go to Start menu -> Devices and printers.
At the bottom, you should see a 'USB COM port (COM...)'
Niek ----What is the part number or link for the USB->TTL adapter you got from Sparkfun?
Do you need to also hook up the USB->TTL adapter GND to the EZ-B GND? Or are you only using the Tx and Rx?
bump
