Audiotoolbox Plugin icon Audiotoolbox Plugin — Enable UWP voices, change default audio devices, capture audio and route it to EZB controllers with session tracking and device control. Try it →
About the only way is to open the bottom of the EZB and remove the speaker.
By doing this, you will remove all sound from JD directly. You would have to play your sounds through your pc instead of through the ezb.
Deborah, do you mean the startup sound? Or are you hearing some form of message?
