Live Stream Broadcast icon Live Stream Broadcast — Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access. Try it →
Rc Rover Esc's
i have an old toy rover laying around at home and i have 4 esc's for brushed motors my rover has 4 motors too as you can imagine, my question is can i control my brushed motor esc's with ez-b by the way i will connect esc's to the power sepparetly i just need to know can i control my esc's with ez-b if i can how ? a quick response would be nice;)
Spain
Helping is a pleasure to have a HobbyKing delagacion near your home? what luck! It would be like a second home to me.:)
one last thing as i said above i will connect esc's power separetly my main power will be a 3s li-po battery there will be 6 ends coming off the li-po (3red,3black) i will connect 2 to my esc's 1 to ez-b is this power supply system okay?
actually they have a warehouse near me same thing you told me to cut off red wire that connects to ez-b but i am sort of scared that it might not work what happens if i connect it without cutting it
Spain
I'm not sure what you mean, if you explain what is what appears in the picture the answer is YES
that was what i meant and and what happens if i odnt cut off red wire you talked about thanks for the diagram by the way
