3-In-1 IMU icon 3-In-1 IMU — EZ-Robot 3-in-1 IMU driver: accelerometer, gyroscope and compass support for motion sensing, orientation tracking and heading/navigation. Try it →
Question With Running Motors On L298n H-bridge
Question With Running Motors On L298n H-Bridge
Hey everyone. Currently my work on the blind device hasn't been quite successful yet. My project involves the use of the L298N H-Bridge to provide connection to two DC vibrating Motors. I am sure I have connected everything properly from the EZ-Board to the H-Bridge, and that both motors are alive. However, when I tried to test one on the H Bridge, not a single pulse was given. If anyone could provide me some help or advice, that would be great. Thanks.~RoboticsMaster.
in general, the light on the H-Bridge is shown and when operated by switches in ARC it works fine. But there is no power going to the motor ports on the H-Bridge.:(
Ireland
Hi Robotmaser have you adjusted the PWM slider
Hello Bravia. As a matter of fact, I have. However, it seems that it still does not let power flow to the h-bridge motor ports. For my Input connections, I have: IN4 as D15, IN1 as D16 ,IN2 as D17, and IN3 as D18, and the power the ground to D19. I assume these are the correct input ports since I can see the leds on the H-Bridge correspond to which directions I put the motors as in ARC. What is your idea of what seems to be the problem? You can tell me if the ports are incorrect, I'm fine with that. Or if there's any other problems, please tell me.:)
Ohhhh. That may seem to be the problem. You see, I have the vcc going to the positive end of a 9 v. battery pack, but I also have ground + 5v. of the HBridge going to D19. So, how do I go about fixing this problem? confused
Ireland
If I understand you correctly you have a connection to D19 ,that is you are using +5v and ground from the EZB to power the motor Remove this and make a direct connection to the battery that powers up the EZB ,try this first
If you use a seperate power source to power H Bridge you will need to connect both grounds together. Pat
