Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
Question With Running Motors On L298n H-bridge
Question With Running Motors On L298n H-Bridge
Hey everyone. Currently my work on the blind device hasn't been quite successful yet. My project involves the use of the L298N H-Bridge to provide connection to two DC vibrating Motors. I am sure I have connected everything properly from the EZ-Board to the H-Bridge, and that both motors are alive. However, when I tried to test one on the H Bridge, not a single pulse was given. If anyone could provide me some help or advice, that would be great. Thanks.~RoboticsMaster.
Forgive me if I'm wrong, but the new connections should be ground of the h-bridge to ground of the battery, vcc to the positive end of the battery, and 5v. to the positive end of the battery? Or vcc and gnd to the negative end of the battery, and 5v. to positive?
THANK YOU SO MUCH!:D It works perfectly now, and everything is connected perfectly! Also, nice to meet you. I'm Alden. It was great talking to you. Perhaps we can form alliances! It's always nice to meet a fellow roboticist. I'll see you around, and thanks much! :D
Ireland
Thank you ,you are very welcome thats what it all about here we help each other have fun with the Hbridge and of course EZB Pat
