On smaller touch screen computers, the PWM slider control the button area of the control needs to be bigger. So then I can change them without using a pen to make adjustments of the control.
Thanks for doing this if possible. j
TCP Clients
— Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections.
I'm not certain what you are asking. Can you explain in a little more detail? Thanks!
I am so sorry for not explaining well. Hope this is better.
j
Ah I see. That track bar object is native to windows - which is why you see it everywhere in windows where track bars are used. The servo slider was created by me to replace that track bar. I'll switch it to the servo slider object that is used else where. The track bar takes up too much space anyway
