Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
Greece
Proplem With Firmware Update
Good afternoon DJ. Sures.
My name is SAKIS . I have the ez-b kit about 5 month. I have a problem with the update firmware V6.5, I did the steps to up date but i can't . This is the message that i saw when i try to update.........
Attempting connection to COM18 EZ-B reports EZ-B Firmware V6.5 Connected T+NAMEsakissending ping sending ping sending bootloader Failed to load bootloader! Have you selected the correct EZ-B COM port? Use the Help menu option to view the online help and watch a video demonstration.
PLEASE HELP ME. REGARDS SAKIS FROM GREECE.
confused
Hello, are you certain that is the EZ-B port? There was never a 6.5 version.
Hello DJ Sures ,
I'm sure that i select the correct port , when i try to connect to ez-b i was read the follow message:
invalid Firmware Version.Please upgrade. EZ- B Reports v 6.5This copy of ARC requires V16
WHAT IS THE PROBLEM?
That error message is because the device you are connecting to is returning a value that the software is mis understanding. My suggestion is to delete the bluetooth EZ-B device, and re-add it. Use the tutorial found on the tutorial page here: https://synthiam.com/Tutorials/Default.aspx?id=5
PS, capital letters are not necessary:)
THANKS FOR THE RESPONSE DJ;)
I'll try right now!
Sorry for the capital letters.
No DJ.
I disconnect the bluetooth device and i connect again with the new ports and i install again the ez-b set up ,but again the same message:
Any other suggestion? confused
How many communication ports are displayed in the drop down of the firmware updater?
6 ports
I Know which is the right port.
