ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
Possible Feature Or Script Help
In ARC there is a "pause" option box for the personality generator and speech recognition. I am wondering if a future update could include a "pause" option in the Movement Panel as well. What I am looking to do is when the robot boots up I would like the Movement Panel to be paused (init script). I would like it to remain in pause until voice command given "enable track motors" is given. If the robot is told to move in any direction while this is paused I would like it to report " my track motors are disabled". Thanks for any and all help! Chris
It is supposed to show what is in the print command in the debug window, but it doesn't. If you run the script in a script object it does show there, so I used them to make sure I had the syntax correct. You can just delete those lines.
Thanks very much! It worked out nicely. I really need to find some time to play more with this software. Thanks again
                               Chris
