Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Only One Com Port On Bluetooth
Hi, While setting up my Bluetooth connection I noticed I'm only given one Com Port option to connect to. In all the instructions I read they say I'll see two choices. I've gone ahead and set everything up useing the one choice given (Com 3) and all seems to work nicely and has been for a couple weeks now. However I'm worried that may change if I dont address this differance now. Do I need to worry and get this fixed or can go on my happy way?
Thanks,Dave Schulpius
NM. Sometimes it helps re-RTFM. I was able to connect through the firmware updater and update the firmware.
