Hi Everyone. Has anyone been able to get the Oculus Rift Camera plugin to work?
3dGuy
— Edited
Ubtech Alpha 1 Bluetooth
— Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs.
Here’s the instructions: https://synthiam.com/redirect/legacy?table=plugin&id=59
Which step of the instructions is causing a challenge? I don’t have a production rift, I have a dk2. So not sure what the differences are. Rift is a pretty complicated system to program for because they keep changing everything
Thanks you for replying DJ.
I have extended the desktop. I have the camera running and EZB connected.
Once I press attach in the plugin the program ARC crashes.
There’s steps missing in your list. What about the driver version? You can find the instructions here: https://synthiam.com/redirect/legacy?table=plugin&id=59
List what steps you aren’t having difficult with please
Note: Until the Oculus SDK and product is consumer stable, this plugin is compiled against Oculus Configuration Utility 1.7 (SDK 0.6.0.1). Download the Oculus 0.6.0.1 runtime here: https://developer.oculus.com/downloads/pc/0.6.0.1-beta/Oculus_Runtime_for_Windows/
The above link just goes to a page not found error.
Not sure what to do from here.
Darn - Oculus, that's not helpful at all
Why did they go and do that...
I'll have to find some time and take a look at what they did to break it.
I did find this page, which has many SDK versions. Which version of the SDK did you end up trying? https://developer.oculus.com/downloads/package/oculus-platform-sdk/1.20.0/
I haven't tried any. I really don't know how to get started with a SDK.
You just install the sdk like any program. That’s what is needed for the plugin to work - Because the sdk contains the drivers. There are different drivers for different applications.
