Ultrasonic Collision Detection icon Ultrasonic Collision Detection — Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling. Try it →
Resolved Resolved by Jeremie!
Needing to source Servo Gears
Needing To Source Servo Gears
Hi there, does anyone know of a place to buy servo gears from? Even better if there is a way to 3D print them so I can make adjustments.
JD Humanoid by EZ-Robot
Ah okay. I’ve never come across anything like that before. So don’t think ezrobot will be able to help.
You’d think something like that already exists out there as a kit. Wonder if anyone here has seen that? A "mechano" type kit that worked with servos would be super awesome. Never come across it before but maybe it does exist hmm
That's alright, thank you for your help. Hopefully I find something.
#11   — Edited
There's always the winch style gears from servo City but they are pricy: https://www.servocity.com/servo-gearboxes/
Otherwise, I'd suggest checking out the inMoov project, the shoulder section has a high torque, servo-driven,  3D printable worm gear.
Alternatively, you could TinkerCAD to design and 3D print gears that are mountable on common servo horns, which shouldn't be too difficult.
*Edit: Yet another solution could be to laser cut acrylic or Delrin gears that mount on servo horns. There are 2D gear generator programs out there that can make this quite easy. I have a laser cutter if you need some assistance, but I'm unsure how far away from each other we are. *Lol, looks like we are a world away Australia is a bit far:D
Thanks so much, that's a great idea of attaching to servo horns already. Which programs can make these 2D gears? I'm not sure if I'll need it due to the first suggestion being so achievable but thank you very much for the offer.
Sweet, thank you very much.
Thank you for your help
