Bought a Kensington 2.1 Bluetooth for it.
It shows a list of ports to select from, none of them work
Any help ?
EZ-Script Console
— Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN.
Any help ?
still no dice.
I have the Generic Bluetooth Radio, and the Generic Bluetooth Enumerator.
When i try to connect to one of the list of Com ports.
It pops up that it wants a password ?
i still have this error btw
Attempting connection to COM3 EZ-B reports EZ-B Firmware V8,5 Connected Usending ping Usending ping Usending bootloader Failed to load bootloader! Have you selected the correct EZ-B COM port? Use the Help menu option to view the online help and watch a video demonstration
.. USENDING Ping?
Are you sure you are using the correct com port? The "EZ Robot" device adds two ports, one for the ARC/EZ SDK program and the other for updating the firmware.
Try removing the EZ Robot device in devices & printers, then adding it again, pairing it with the code 1234.
Have you watched the Connections tutorial?
click here for tutorial
It has all the answers you need
its working now
thanks
What was it in the end? (It'll help anyone else who searches with a similar problem)
It was the uninstalling of the drivers that came with it. (Cd of Toshiba drivers)
Then, i had to seek under the Software Installer for the 'toshiba bluetooth stack'
And deinstall that.
After that, i had to reboot windows.
And let the bluetooth be found again by windows.
After that, i also had to 'pair' the connection And type in '1234' as code.
** like discribed in this Tutorial Page
.. And after that, no problems. could just opdate
