Conversational Menu icon Conversational Menu — Voice menu tree to navigate options and run scripts on ARC robots. Multi-level, customizable prompts, speech I/O, timeout and repeat/back. Try it →
Microphone Audio
Does the Voice Activity and Microphone audio only work with the EZB4 soundboard and not the Pc soundboard?
Microphone by Synthiam
Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback.
rephase
Microphone audio control work with the pc soundboard?
#4   — Edited
Ok so when I try to export it form the microphone control, it only come s out of the SoundBoard EZ-B v4., not the pc sound board
Quote:
The most recent recording in the buffer can be exported to a SoundBoard EZ-B v4.
Oh - the export does that yah. You got your answer:)
oh btw if you wanna record audio to import into a soundboard, use audacity. It's free: https://www.audacityteam.org/
The microphone can't export to the soundboard PC because it's not the correct format audio file.
#7   — Edited
Can that be updated?
I have audacity
