TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Message Recieved When Trying To Add
What is wrong? Never seen this before... upgraded to latest version. Using new IOTiny...
Error when selecting any script control...
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.ArgumentException: Parameter is not valid. at System.Drawing.Image.get_RawFormat() at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y, Int32 width, Int32 height) at System.Drawing.Graphics.DrawImage(Image image, Rectangle rect) at System.Windows.Forms.PictureBox.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder Assembly Version: 2015.8.9.0 Win32 Version: 2017.03.06.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-Builder.exe
PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EZ_B Assembly Version: 2015.7.28.0 Win32 Version: 2017.03.06.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
EZ-RibbonMenu Assembly Version: 2015.7.3.0 Win32 Version: 2016.12.19.0 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-RibbonMenu.DLL
Alsing.SyntaxBox Assembly Version: 2015.5.15.0 Win32 Version: 2016.12.19.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/Alsing.SyntaxBox.DLL
WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Web Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
CefSharp.Core Assembly Version: 53.0.1.0 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/CefSharp.Core.DLL
CefSharp Assembly Version: 53.0.1.0 Win32 Version: 53.0.1.0 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/CefSharp.DLL
CefSharp.WinForms Assembly Version: 53.0.1.0 Win32 Version: 53.0.1.0 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/CefSharp.WinForms.DLL
FFMPEG Assembly Version: 2013.8.13.0 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/FFMPEG.DLL
System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Web.Services Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.ServiceModel Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
IO Tiny connection details....
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: Screen Resolution: 1366x768 (96x96 dpi) Version: 2017.03.06.00 Attempting connection on 10.0.0.224:23 Connected to 10.0.0.224:23 Reports EZB v4 OS IoTiny EZ-B v4 IoTiny ID: 222-222-222-222-222-222-222-222-222-222-222-222 EZ-B v4 IoTiny has temporarily configured the audio pre-buffer to 5,000 Bytes for this session. (Options -> Preferences -> Audio) Setting battery monitor voltage: 7 Setting battery protection: True Setting i2c rate: 100000 EZ-B voltage is 9.285291336 EZ-B temperature is 24.76099144578371760C Connected
awesome to see the AI answer the question correctly before any of us:D nice work support robot. guess you can mark this as resolved and give credit to the robot
DJ I have done the following:
  1. scanned for virus - none.
  2. Re-installed .Net
  3. Uninstalled and reinstalled ARC
  4. Checked for low memory issues - none (6MB ram, using only about 1.5 while running).
Problem is still present. I have ran on the same PC for several years and had no problem.
Problem not noticed before upgrading to your March 6 update. I last updated on 1/31/2017 with the build at that time.
Any further assistance would be helpful.
Thanks.
DJ, Problem went away with 3/20/2017 update.
